New Here! BizHub Pro Di850 Question
  • Lori_Ann
    Hi! I just registered and this is my first post.
    I am hoping for some help with a Di850. I can't get it to feed 4-part NCR. Using Appleton XERO FORM II which is recommended for this model (reverse sequence out of drawers), but first sheet jams every single time!
    I need help!
  • nmfaxman
    • 1702
    Did you set the drawer for thick paper?
    You also need to adjust the lift sensor for paper curl.
    • Lori_Ann
      I did adjust the drawer for thick paper, thin paper, normal, fine and everything in between.
      How do I adjust the lift sensor?
