C6500 Remote Panel
  • orestesp
    • Sep 2019
    • 226
    [Misc] C6500 Remote Panel
  • tsbservice
    Field tech
    • 8020
    Re: C6500 Remote Panel
    Hi orestes,
    Firstly, can you ping it?
    • orestesp
      • Sep 2019
      • 226
      Hi orestes,
      No it fails with "Destination host unreachable" if I recall correctly.
      • tsbservice
        Field tech
        • 8020
        Then I would try to connect it exactly in place of working machine using working machine IP settings and cablings.
          are they on the same router?
          a different router will have a different IP range
          • orestesp
            • Sep 2019
            • 226
            Both are on the same router/network.
            I will try disconnecting everything from power and reconnecting them, as well as a 3rd cable, just in case and let you know.
              ok next step then... get your laptop config'd for the copier IP addy.. you MAY need a crossover cable ( not sure about that unit ) or just plain cat5 cable .. see if you can see the copier web page... that'll eliminate the possibility of NIC card probs on the copier.. from there ( if it works also try printing from lapper) IF it works I would hand over the problem to THEIR IT group .. unless your contract states that YOU handle the IT problems.
              Make sure if you get it working from your lapper to have their IT guy standing there so he cannot dispute your findings .. When i print from my lapper I print out the WINDOWS test page showing your laptop name.. IP addy that was used... and print internal network config pages too.
              That way there is NO QUESTION that the copier isn't the problem but THEIR network is.
              Did you setup the copier in your shop and print/scan to it then? if so do you still have the config pages from that? ( something as Service manager I DEMANDED from my setup crew )
              • tsbservice
                Field tech
                • 8020
                Have you tried to review this thread?
                C6500 install. Fiery and driver cannot locate Printers IP address.
                • tsbservice
                  Field tech
                  • 8020
                  Phil I believe orestesp is print shop owner with some knowledge who appreciated techs experience.
                  This should be machine for his own shop.
                  • orestesp
                    • Sep 2019
                    • 226
                    Yes indeed this is my own shop. I happen to have a crossover ethernet cable, when I go back to my shop on Monday I'll go over the simple things once more and give a read to the thread that you've linked to see for any potential solutions.
                    It's probably something I have overlooked, I couldn't do much experimentation with the networking equipment as other machines were in use at the time and I couldn't take them offline.
                    I'll let you know what happens.
                    Thank you to you both.
                    • Toxic
                      • 698
                      Lan cable plugged in the machine body or into controller?
                      • orestesp
                        • Sep 2019
                        • 226
                        To the body, apart from the controller.
                        Sent from my Redmi Note 5 Pro using Tapatalk
                        • Toxic
                          • 698
                          Did you try read topic @tsbservice posted before?
                          I never used lan port on main body,only on fiery.
                          https://www.copytechnet.com/forums/k...tml#post599125
                          • raplma
                            • Mar 2017
                            • 139
                            Hi Orestes
                            Glad things are doing ok at your shop.
                            Late to the party as always and may now not be relevant.
                            We regularly use the web interface direct to the print engine on our c5501 and so confirm it works.
                            We use Firefox and simply type the IP address for the print engine into the address bar no / or \ etc. just xxx.xxx.xxx.xxx
                            Two things to check:
                            Use an IP scanner - I used one called "advanced IP scanner" - this will list all visible connected equipment on your network and if you widen the IP search range it will double check that the machine isn't sitting there on a different IP range despite you telling it what it should be. So I would enter the search as 192.168.0-10.0-255, of course your ranges may be quite different. If you use this search app, Fiery's tend to be listed in the manufacture column as Tyan Computer Corp, whereas the print engines are listed as Konica Minolta Holdings, so despite that name which may be c6500 for both in your case you can still tell if you're looking at a Fiery or Print engine.
                            For comparison below are our NIC settings, in case a comparison with a setup that works helps.
                            FYI we have a simple network set-up, a single commercial grade router, which then has a further four basic 16 port switches attached installed in each office area, the router is set to allocate the IP addresses.
                            Cheers
                            Mark
                            • orestesp
                              • Sep 2019
                              • 226
                              Hello everyone,
                              Unplugging everything on my network and plugging it back in again fixed the issue.
                              Thank you to everyone who took the time to reply.
