Scanner problem squares Bizhub C203
  • furius
    • Jan 2018
    • 34
    Hi guys, I have this problem on a C203 that has the mfpb replaced.
    I have already tried machine initialization and entered the scanner serial!
    Do you have any suggestions?
    20200901-101318 — ImgBB
  • Toxic
    • 698
    Re: Scanner problem squares Bizhub C203
    You should do full complete installation procedure from scratch.
    • Synaux
      • Mar 2012
      • 1224
      DING DING DING SHAME SHAME - YouTube
      • furius
        • Jan 2018
        • 34
        Have already performed the machine installation procedure as per manual, but unfortunately without results
          • 30299
          run it again
          • Toxic
            • 698
            run it again
            ...and follow procedure blindly,do not skip any step.
            Long ago one of my coleague (rookie in that time) ask senior technician why some steps in install or service manual is not logical in some cases.
            He got answer, if in manual says "run 3 circles arround machine", do it or you can have troubles later.
              damn rookies... I had one decide which screws weren't needed.. he only put 2 of the 4 screws back on a main drive motor.. back in the days of chain driven analogs
              didn't fair well for him at all
              • furius
                • Jan 2018
                • 34
                I'll try running the whole installation process again and let you know
                Thank you guys
                • Synaux
                  • Mar 2012
                  • 1224
                  Thank you guys
                  Double check:
                  Date and time enter in one location
                  Touch panel not adjusted
                  (I bet the person(s) responsible for this gets a wet spot in their pants every time someone forgets to do one little thing in this procedure. Perhaps there is valid reason for this, but I feel like this is just a troll-maneuver.)
