ICP19 Bizhub C552
  • escalante
    • Sep 2018
    • 115
    ICP19 Bizhub C552
    Good night. I need your help. could not locate the ICP19 in the technical service manual.
    I want to know what controls or what component can affect if it is damaged.
    Enviado desde mi SM-J701M mediante Tapatalk
  • Synaux
    • Mar 2012
    • 1224
    Re: ICP19 Bizhub C552
    There is no ICP installed in the pictures you posted so these boards are probably printed with the intention of being used for multiple purposes.
    It is not in my manual either. The only conclusion I can make is that is does not exist (unless you took it off).
    I do not recognize the board from the close-ups, what board is that anyways?
    • zoool
      • Nov 2016
      • 52
      look on other side and show that photo.
      • allan
        RTFM!!
        • 5445
        This is a bit backwards.
        Machine faulty?
        Is that ICP blown?
        Trace it to the connector pin its attached to then find the connector pin number in the diagrams in the manual then check where that goes to.
        Normally the 24V/12V/5V comes in to the print and the the ICP's are for protection on out going supply from there.
        Whatever
        • escalante
          • Sep 2018
          • 115
          Good evening colleague.
          Thank you for your comment.
          Tell him that I found information on ICP19 in a Bizhub C452 solution guide.
          In this forum there is a topic related to this problem.
          Topic: C451..Replace all toner cartridges is displayed.
          Link:
          The information attached is from the Bizhub C452
          thank you
          Install toner cartridge message for any color after replacing toner with new cartrid.pdf
          • zoool
            • Nov 2016
            • 52
            if the ICP is blowed them use a wire and make a bridge on the ICP for check.
