C3300i/C4000i/C3320i/C3350i/C4050i Fan (FM3) issue
  • kaisa
    • Sep 2019
    • 6
    Hello, i have some sparrow machines with this problem:
    When the device is in sleep mode, and apparently without any reasons, the FM3 fan runs for a 1 min stops a 1min and so on.
    Does anyone have a solution for this problem?
  • tsbservice
    Field tech
    • 7911
    Re: C3300i/C4000i/C3320i/C3350i/C4050i Fan (FM3) issue
    At what FW version Sparrows are? Earlier i-series FWs are full of problems.
    • kaisa
      • Sep 2019
      • 6
      FW is G00-B5
      • Bix
        • Apr 2018
        • 1421
        I confirm that I have had this problem. But with the printer turned off! Yes, you got it right. I turned off the main switch and the fan continues to run for 5-10 minutes. I usually resolve by unplugging for 10 seconds.
        • robinsonad86
          • Aug 2014
          • 67
          These printers keep a small voltage running through them even when powered off but still plugged in. There is a bulletin on Infohub something to do with quick start
          • Bix
            • Apr 2018
            • 1421
            Yes, I am aware of this. But I think this is strange. Usually it doesn't. When this happens it's because the printer freezes (goes offline, unknown jams, etc.)
            • B0265
              • Jan 2007
              • 718
              As I understand it the fan starts when there is some network activity. I found the the fan starts more frequently after I activated AirPrint.
              • hobbele
                • Nov 2019
                • 38
                Has anyone of you already installed the modification for this?
                There is a modified PWB for this...
                We installed this for a customer and now we keep getting the error code 5372...
                Firmware: GG3-E9
                Release of <Other> [bizhub C4000i Series] [FW ver. GG3-E9] The noise of the fan (FM3) on PWB-BASE-Assembly is very loud
