BH-C-25, "Toner not installed, Y-K"
  • Hansoon
    • Sep 2007
    • 3374
    Rental machine, BH-C-25, showing "Toner not installed, Y-K"
    Machine is in a remote location. Customer got this indication and replaced toner Y and K. Machine was up again and tested. The config sheet showed 100% for CYMK toner. Machine worked fine the whole day for copying and printing but the next morning the same stupid message came up: "Toner not installed, Y-K" and doesn't go away inspite of slamming the IU's and toners in and out as the customers says.
    I will go there Monday to clean contacts of the IU's and tonercartridges but I fear that is will not be that easy.
    Any experience with these kind of errors? Any ideas?
    Hans
  • blazebusiness
    SanDiegoCopierRepair.com
    • 1250
    Re: BH-C-25, "Toner not installed, Y-K"
    Hans
    I would suspect a toner supply issue so:
    Check toner shutter
    Generic supplies? (since it's you replacing it, I imagine not)
    Whats the current Image units life?
    And, of course with any weird problem/glitch I always start with rewrite firmware.
    Not the same machine but I remember the C20's were a pain with this type of issue.
    • Hansoon
      • Sep 2007
      • 3374
      Heard the rumour that DIPSW 28 can forcibly release the toner cartridges, but how to set it for that purpose? What HEX setting?
      Hans
      • allan
        RTFM!!
        • 5462
        Seen bad drum chips cause this before.
        Whatever
