Bizhub 3301p
  • antone
    • Oct 2014
    • 344
    Bizhub 3301p
    message on control panel...Bin Full ..not sure what's this mean!!
    Sent from my SM-N950U using Tapatalk
    Re: Bizhub 3301p
    man the bin (output) is full or the sensor is broken
    • blazebusiness
      SanDiegoCopierRepair.com
      • 1257
      Re: Bizhub 3301p
      4.4 Understanding the printer messages
      4.4.1 Bin full. Remove paper.
      Remove the paper stack from the standard bin.
      So, check where the prints exit at the top of the printer. There is a sensor flag on the right hand side as you face the front of the printer. That flag triggers the "NARROW MEDIA/BIN FULL SENSOR"
      Flag is stuck
      or
      Flag is broken
      or
      Paper in the bin reached a height which correctly triggered the sensor (so remove paper)
      • tsbservice
        Field tech
        • 8028
        Re: Bizhub 3301p
        Like they both said it's exit tray regarded as output bin. I believe due non KM origin of this model.
        • antone
          • Oct 2014
          • 344
          Re: Bizhub 3301p
          Took a part copier..cleaned senors All set ! exit senor
          • tsbservice
            Field tech
            • 8028
            Re: Bizhub 3301p
            Hi antone. Did you receive my PM?
