Konica Bizhub 808 disable SMB 1.0
  • pstoric83
    • Mar 2020
    • 34
    I believe we have the newer firmware that can do this but I'm not sure where the setting is. I logged in as admin and went to Network > SMB Settings and I thought it was under "Client Settings" but I'm not sure what to change to get it to scan to our server 2019 using SMB 2.0/3.0? Am I looking in the correct spot? Currently it's set to NTLM V1
    World's leading screen capture + recorder from Snagit + Screencast by Techsmith. Capture, edit and share professional-quality content seamlessly.
  • tsbservice
    Field tech
    • 8031
    Re: Konica Bizhub 808 disable SMB 1.0
    https://www.screencast.com/t/TgeuMIaQ
    NTLM1 is no go. At What exactly FW version is your machine?
    • pstoric83
      • Mar 2020
      • 34
      Here is what I see on the ROM version page. I can switch it to NTLM v2 on the page in the screenshot above but not sure if that's the correct setting or not.
      ROM Version
      MFP Card Version A7950Y0-F000-GP2-W5
      MFP Controller BOOT Program A7950Y0-1E00-G00-05
      MFP Controller Linux Base Linux-3.10.68
      MFP Controller Kernel Program A7950Y0-1C00-GC1-83
      MFP Controller SubSet A7950Y0-1F00-G00-W4
      MFP Controller A7950Y0-0100-GP2-W5
      MFP Controller System A7950Y0-1000-GP2-W5
      MFP Controller Print Controller A7950Y0-3000-GP0-W1
      MFP Controller Print Controller Font A7950Y0-3F00-G00-U2
      MFP Controller Print Controller Demo Page A7950Y0-3E00-G00-00
      Image Reader Controller A7950Y0-8600-G00-B2
      MFP Controller MIO A7950Y0-5000-G01-C1
      Operation Panel Message Data A7950Y0-8100-GC1-W5
      MFP Controller PIC A7950Y0-8200-G00-F0
      MFP Controller PIC Image Parameter
      MFP Controller Thread Image Parameter
      MFP Controller IR Image Parameter
      Finisher A87G0Y0-0071-G00-14
      Machine Controller A7960Y0-0200-G00-41
      Machine Controller BOOT A7950Y0-0210-G00-01
      Machine Controller Printer A7960Y0-0220-G00-38
      Machine Controller Media A7960Y0-0230-G00-03
      Machine Controller IO A7960Y0-0240-G00-00
      Machine Controller Scanner A7950Y0-0300-G00-09
      ADF A7820Y0-0024-G00-06
      Fax Board Controller1
      Fax Board Controller2
      Fax Board Controller3
      Fax Board Controller4
      SD
      DSC1
      DSC2
      PK
      PI
      Panel CPU A7PU0Y0-8900-G30-03
      SCB A79J0Y0-1A00-G00-03
      Power Sub-CPU A7950Y0-1900-G00-81
      SATA Controller A7AH0Y0-6403-G00-04
      Integrated Printer Driver Version 5-4.2-0-GP2-W5
      Movie Data A7950Y0-C000-G00-90
      Voice Data
      Dictionary Data A7AH0Y0-B100-G00-01
      OCR Library
      Authentication Customize Data
      Panel Sound Data A7PU0Y0-C200-G00-00
      Loadable Device Driver1
      Loadable Device Driver2
      • srvctec
        Former KM Senior Tech
        • Oct 2009
        • 827
        Yes, that is the correct place to change the setting.
        Started in the copier service business in the fall of 1988 and worked at the same company for 33.5 years, becoming the senior tech in 2004 but left to pursue another career on 4/29/22.
        • tsbservice
          Field tech
          • 8031
          Thanks man I forgot to reply him. My bad seems the weight of age is beating my experience
          • pstoric83
            • Mar 2020
            • 34
            So under client setting change it to NTLM V2?
            • srvctec
              • Oct 2009
              • 827
              Well, if you want to force it to V2 only, then yes.
              • blazebusiness
                SanDiegoCopierRepair.com
                • 1257
                On the Konica's there is also a software switch setting for SMB:
                For SMB you can verify what's enabled in Dip sw 219
                Hex 00 enables SMB 1 & 2
                Hex 04 enables SMB 2 only
