32-04 32-02 jam code series 4e
  • koni123
    • Sep 2011
    • 13
    [Jamming] 32-04 32-02 jam code series 4e
    Jam code 32-02 32 -04 serie 4e ,intermittant first copies duplex
  • Bix
    • Apr 2018
    • 1421
    Re: 32-04 32-02 jam code series 4e
    Hi, unfortunately we are not telepathic. You can provide more details:
    - Status of the rollers?
    - Does it happen with all the trays?
    • Toxic
      • 697
      Read this topic
      C224e duplex jams
      • splblazer91
        • Jul 2014
        • 204
        Replace the Exit Assy.
        • Jumping Jack Flash
          • Jul 2009
          • 66
          Originally posted by Toxic
          Read this topic
          C224e duplex jams
          I agree with "Toxic" , always 1 copy or printout after coming to work
          • blazebusiness
            SanDiegoCopierRepair.com
            • 1257
            Very common issue on the 4 series.
            Do not try parts first.
            Instead:
            In service mode - Set fuser warmup to mode 3 and temp settings to minus 10 for each paper size. That will most probably fix your jam issue without parts.
