Bizhub 4052
  • antone
    • Oct 2014
    • 344
    Bizhub 4052
    replenish paper message ...only 400 copies..everything looks great!
    Sent from my SM-N950U using Tapatalk
  • tsbservice
    Field tech
    • 8031
    Re: Bizhub 4052
    What Konica tech support said? This is basically new unit.
    Intermittently or you've seen it?
    • antone
      • Oct 2014
      • 344
      Re: Bizhub 4052
      not intermittently..no help from konica at all. i notice on paper tray does rise up when
      inserted.plate should come up
      • Bix
        • Apr 2018
        • 1421
        Re: Bizhub 4052
        There is a sensor hanging over the paper tray. Sometimes, by reinserting the tray, someone is able to break it. If so, it should be replaced.
        • tsbservice
          Field tech
          • 8031
          Re: Bizhub 4052
          Agree check MEDIA PRESENT SENSOR (PS12) under [State Confirmation] -> [Sensor Check] for proper operations.
