Print problem in konica c284
  • enricocopyline
    • Jun 2018
    • 122
    good evening everyone
    what can be causing this problem?
    I have already replaced developer, drum, belt and mfpb
    with one mfpb it gives the problem in magenta with the other in cyan
    SKMBT_C25320101216250.pdf
  • tsbservice
    Field tech
    • 8002
    Re: Print problem in konica c284
    PH unit(laser)? Check cables between PH and MFPB if you have another one in working conditions just swap it.
    • enricocopyline
      • Jun 2018
      • 122
      thank you very much checking the flat is a little bit ruined and I think that's it
      • Blizzoo
        • Aug 2013
        • 608
        A faulty Cyan Erase Lamp, looking at your attachment assuming it's printed LEF, can cause a repetitive image?
        • rrrohan
          • Sep 2011
          • 1977
          How does the cable get damaged?
          Sent from my Pixel 4 XL using Tapatalk
          • Bix
            • Apr 2018
            • 1421
            A mouse haha
