Faded prints out on second side.
  • Terna247
    • Jan 2019
    • 64
    Hi top techs. For the second time I encounter this problem. The machine prints well on one side.
    The second side is washed away!
    These are my attempts to this so far;
    Changed the HV board11
    Changed the degaussing coil
    Changed the power board
    Changed the IH board.
    Changed the whole 2nd transfer assy including the transfer roller.
    These two machines are almost lying waste here. Let's get them back to life.
    BIZHUB 451.
    Sent from my Infinix X606C using Tapatalk
  • allan
    RTFM!!
    • 5462
    Re: Faded prints out on second side.
    Have you adjusted the second side transfer settings in service mode?
    Whatever
    • Terna247
      • Jan 2019
      • 64
      No allan, am just doing that now. Hiking them to +5 now.........
      • Terna247
        • Jan 2019
        • 64
        After the adjustments, did run stabilization, test printed..... No luck.
        Rather it gave me a crack crack noise as if the the cleaner gear on the ITB is about failing, so I turned down the adjustments immediately. Printed without noise but same problem.
        • allan
          RTFM!!
          • 5462
          Are you using some kind of special paper?
          Some paper will not allow good transfer on the second side.
          The second side transfer is normally set higher.
          High humidity?
          Whatever
          • allan
            RTFM!!
            • 5462
            Do a manual duplex print by feeding the paper from the tray a second time.
            Whatever
            • Terna247
              • Jan 2019
              • 64
              I fed in Bond paper which in not rougher than conqueror.
              I guess am running normal humidity here..
              Yes I printed on the second side. Which is *2 worse. I image washes worse on the second side.
              Thought at first the second transfer assy will solve this as a bulletin suggested.
              • tsbservice
                Field tech
                • 8026
                Check this old bulletin. Your machine may miss that sheet.
                Guide sheet mod.pdf
                • Terna247
                  • Jan 2019
                  • 64
                  tsbservice I appreciate your willingness to help I couldn't just get to the attachment.
                  I can view it if you drop it in my mailbox. gbaaterna101@gmail.com. thanks.
