Konica Minolta C454e- Disable User Settings Password
  • Lydah
    • 3
    Hi all,
    I have a C454e here which has a user settings password.
    I would only like it to be set on administrator setting alone. I believe there's a SW switch for disabling the user settings password.
    Will really appreciate your kind response.
    Thanks.
  • Terna247
    • Jan 2019
    • 64
    Re: Konica Minolta C454e- Disable User Settings Password
    You could either delete the user boxes registered with those user passwords..... Unless you are talking about the CE password
    Sent from my Infinix X606C using Tapatalk
    • rrrohan
      • Sep 2011
      • 1977
      Originally posted by Lydah
      Hi all,
      Thanks.
      200 set to HEX 20
      • Lydah
        • 3
        Its not the user box password. Its the User Setting in the Administrator Settings>Utility which they have enabled the password.
        Thanks for your response
        • Lydah
          • 3
          Originally posted by rrrohan
          200 set to HEX 20
          Have tried and it enable the utility password but I disabled it again.
          • Sendragon
            • Jan 2020
            • 3
            Switch: 71 Hex: 0 ?
            • allan
              RTFM!!
              • 5462
              Backup and wipe the machine loose the machine settings.
              The right answer is out there. I am just to lazy to read.
              Whatever
              • ezzysi
                • Oct 2008
                • 77
                Originally posted by Sendragon
                Switch: 71 Hex: 0 ?
                Its an old thread now but this has just helped me out !!
                Worked on a C258, before changing 71 to 0 the user settings were locked and couldnt do a meter count print off without inputting the admin password.
