How to clone ic204 print controller from bh420-500
  • t123456789
    Hi All
    I'm try to connect to print controlller (IC number = CY8C24123 ) via pro-pSoC with RS-232C but has error message "ID not match"
    if u can, please let me know.
  • TheOwl
    • Nov 2008
    • 1732
    I don't believe that the RS-232 port is directly connected to the print controller. Just like the NIC, the RS-232 port is mounted on the main board.
    If I have guessed right, then if you want to clone the chip on print controller, then you will probably have to desolder it from the board. Thing is, and I'm not sure on this one, there might be legal restrictions in doing so.
    • t123456789
      Thankz for ur reply , TheOwl
      I'm sorry for my mistake communication. English isn't my first language.
      I already remove the chip from the mainboard then i try to clone the chip but has an error message when connecting to access the chip by PSoc Programmer Kit via RS232.
      thank again.
      • pepper38_cnd
        Field Service Manager
        • Aug 2005
        • 1075
        I think it may have some safe guards to prevent you from doing what you want to do. Obviously you are very knowledgeable but I've attached the data sheet for that chip if other may be interested. Let us know if you are successful.
        Online Store is closed. Chip resetting is a thing of the past! Thank you to all my past customers.
        Now into Ip TV KODI Boxes
        • harry2007
          • 52
          RS 232
          The serial ports on bizhubs are mounted for CSRC (remote care) communication.
          http://copierservicereset.com
          • pepper38_cnd
            • Aug 2005
            • 1075
            What software are you using, PSoC Express ?
