C3320i C9701
  • DDmario
    • Feb 2020
    • 1
    [Error Code] C3320i C9701
    Hello, I have a relatively new C3320i that keeps showing the error C9701. I have already replaced the CIS and the ribbon cable.
    Has anyone had such a case?
    Thanks for your help.
  • Bix
    • Apr 2018
    • 1421
    Re: C3320i C9701
    Hi, have you tried the CISRYB connections?
    • techlogic
      • Dec 2019
      • 4
      Re: C3320i C9701
      • Alex HRO
        • Mar 2021
        • 3
        Re: C3320i C9701
        Hello everyone
        We have had this error in the current 50s i-series for some time now. We now also have a backorder at Konica-Minolta for the scanners.
        Is there a solution to the problem and do other technicians also have to deal with this error several times? In any case, the packaging of the devices has not improved in the last 2 years :-(
        • barber782
          • Aug 2011
          • 281
          Re: C3320i C9701
          In most case it was the scanner ribbon cable at fault, visible damage.
          If you need to check the CIS is working you can swap it with the one in the ADF on the 3350i's, for fault finding purposes.
          • Alex HRO
            • Mar 2021
            • 3
            Re: C3320i C9701
            Hey colleagues
            there is probably a change in the ribbon cable routing on the CIS housing of the scanner.
            I'll take a look and have ordered the parts.
            Many greetings from Germany :-)
            • DijanJanssen
              • Jan 2016
              • 7
              Re: C3320i C9701
              Hi,
              Tip! Change the "Scanner Flat Cable" and "Frame", also replace the connectors when you replace the cable
