My bizhub c224e Problem to connect in admin mode
  • r6po
    • Apr 2020
    • 15
    I have a bizhub C224e, I recently changed my ssd. It worked very well for 2 months.
    The guest mode works fine, but it is impossible to switch to admin mode.
    There is an SLL security issue. Could someone help me? advise me ?
    thank you
  • emujo2
    • Mar 2017
    • 1579
    Re: My bizhub c224e Problem to connect in admin mode
    Your browser has most likley cached the old SSL settings. When the SSD was replaced SSL was turned off. You can try a different browser (firefox to chrome ie) or simply clear your browser's cache. Most browsers are going to pop up with a "are you sure you want to go here" message as the SSL cert is self signed and is not inherently trusted. E
    • r6po
      • Apr 2020
      • 15
      it does not work
      • mearmi
        • Oct 2010
        • 350
        Originally posted by r6po
        it does not work
        Did you try Firefox and Internet Explorer?
        • r6po
          • Apr 2020
          • 15
          Yes I try firefox, IE, Chrome, Safari.
          i thinks the ssl certificate has expired.
          • tsbservice
            Field tech
            • 8081
            You can try Initialize All in System 1.
