C3350i series in box pre-start leaflet
  • EarthKmTech
    Step aside, noob
    • May 2009
    • 2139
    For those unaware, you are now expected to remove and shake all 4 imaging units prior to the first power on. This is a standard leaflet now placed inside the box.
    Informations supplementaires_201110074701.pdf
  • Bix
    • Apr 2018
    • 1421
    Re: C3350i series in box pre-start leaflet
    I hope this is only for a certain batch of C3350i.
    Soon they will send us the pieces in single parts and then they will tell us to assemble the printer on site.
    Can I find out with which firmware that printer came to you from the factory?
    • Genotrom
      • Feb 2020
      • 77
      thanks for report!
      • EarthKmTech
        Step aside, noob
        • May 2009
        • 2139
        Brand new stock opened today. I don’t recall what was on there but it was fairly recent. Stuff we get is straight from the factory, it doesn’t sit around.
        The TCR sensor on these things is like nothing I’ve ever seen on a KM. I suspect this new design can’t handle settled developer at all.
        • Bix
          • Apr 2018
          • 1421
          On A3 they did a good job. Yes, there has been some bugs but now they look ok!
          On the A4 series it is worrying. Now the black and white versions will also arrive but I hope they are only a few cases.
          • EarthKmTech
            Step aside, noob
            • May 2009
            • 2139
            • Bix
              • Apr 2018
              • 1421
              Yes, the A4s are now produced by Konica Minolta. But not all of them.
              Bizhub 4000i/5000i/4020i etc are from Brother.
              Bizhub 4020/4050 are from Lexmark.
              Bizhub 4052 is Konica Minolta with Lexmark engine.
              A4 color printers (C3320i, C4050i etc.) are all Konica Minolta. For the first time Konica Minolta will launch the A4 black and white 4050i printers etc.
              • SimoneCariz
                • Jan 2018
                • 7
                [ATTACH]47263[/ATTACH]
                Thank you!!!
                • srvctec
                  Former KM Senior Tech
                  • Oct 2009
                  • 827
                  I sure wish KM would get onboard with the mantra: "If it ain't broke, don't fix it!!" No issues with TCR sensors (that I've seen in the field) really for many years now and they go and change them.
                  Started in the copier service business in the fall of 1988 and worked at the same company for 33.5 years, becoming the senior tech in 2004 but left to pursue another career on 4/29/22.
                  • tsbservice
                    Field tech
                    • 8032
                    That's why I always follow install instructions no matter how many machines installed before.
                    Now for the A4 machines, I'm with Bix on this one. New A4 color bizhubs are KM own design pretty much as older models. Mono color A4 are rebadged mix.
                    • EarthKmTech
                      Step aside, noob
                      • May 2009
                      • 2139
                      FYI, I know the a4 colour is KM own design- note I said BW (black and white)
                      • pining
                        • Sep 2021
                        • 3
                        What about firmware for 4020? is same with Lexmark? and have some craked firmware to no more chips count?
                        • tsbservice
                          Field tech
                          • 8032
                          Lexy 4020 crappie machine has nothing in common with bizhub C3350i.
                          Please start your own thread to feed your curiosity.
