C2404
  • Engradenuga
    • Nov 2020
    • 4
    [Error Code] C2404
    I have a machine I am currently working on. Its Konica Minolta 1070 with error code c 2404. How do I go about it.
  • allan
    RTFM!!
    • 5462
    Re: C2404
    Obtain a service manual.
    Then describe the problem in full and what you have tried to do to repair the problem.
    If you are not a tech then getting someone out will be a good idea.
    See these machine go from bad to worse if an inexperienced hand gets to it.
    Whatever
    • Engradenuga
      • Nov 2020
      • 4
      Re: C2404
      Already checked the service manual. The code was referring to the erase lamp. I am sure the erase lap isn't faulty and the fuse on the PRCB is still intact. The code comes and goes at intervals
        Re: C2404
        how are you sure? Have you left the door pegged and watched it come on and go off?
        a tech of 2-10yrs should explain the problem in more detail if he requires help.
