Konica Minolta C284e Scanning issue (Sent as mime-attachement)
  • mearmi
    • Oct 2010
    • 344
    [Misc] Konica Minolta C284e Scanning issue (Sent as mime-attachement)
    Hi All
    Client is scanning (email) documents as pdf but getting as mime-attachments. And cannot open as pdf.
    Another issue is when she scans 10 pages. it comes separately as 10 emails :
    Message from C284e [1/2] to [10/10] 10 separate emails.
    Please advise.
    Thanks and Regards,
    mearmi
  • Bix
    • Apr 2018
    • 1421
    Re: Konica Minolta C284e Scanning issue (Sent as mime-attachement)
    Hi, most likely they have activated this.
    You have to remove.
    • CP-1015
      • Nov 2020
      • 285
      Hi,
      what file extension get your client? You can chose file type in Scan menu.
      • mearmi
        • Oct 2010
        • 344
        Originally posted by CP-1015
        Hi,
        whatever File type you select PDF JPEG TIFF. They get as mime
        • tsbservice
          Field tech
          • 7635
          Try to turn off S/MIME under [Network] - [E-mail Setting] - [S/MIME]
          • mearmi
            • Oct 2010
            • 344
            it is already off
            • rrrohan
              • Sep 2011
              • 1971
              If mime isnt enabled at copier then logically it has to be a I.T issue
              • mearmi
                • Oct 2010
                • 344
                FTP scan is fine.
                only getting the issue in scan to email
                • xagerated
                  • Mar 2020
                  • 9
                  There are a few things that I would try. First off try it with different smtp settings instead (gmail, outlook, etc), see if you are still getting the same problem. If you are, then you know that there is probably a setting that you are missing in the machine itself. If not, then the problem lies on the email server side. Also, check if the machine is trying to encrypt or to add a digital signature to the scan to email and turn that off if it is.
