SMB Server on i series
  • rrrohan
    • Sep 2011
    • 1977
    Am i misunderstanding the point in SMB server?
    If I enable it and turn it on I can save a document from copier and access it via PC smb folder but If i put a PDF in the folder at PC it doesnt appear in userbox at the copier.
    Was hoping to use it to quickly transfer userbox from old copier into new one
  • REGSIS
    • May 2016
    • 440
    Re: SMB Server on i series
    I think that I tried that too, but it didn't work.
    You can allways use option in printer driver preferences "save to user box" but that is time consuming if you have many documents.
    • rrrohan
      • Sep 2011
      • 1977
      i guess could be handy for certain situations like scanning without setting up email on copier or SMB on PC just have the PC browse to the copier and download that way.
      just surprising after all these years they still dont have a easy way to transfer userbox data
      • Bix
        • Apr 2018
        • 1421
        Hi, these iSeries have very high security protocols. I wouldn't exclude some flags that block writing (so read only to extract files). This is to prevent some files from compromising the printer. Just a thought.
          • 30570
          You can transfer the names only not the content
          • tsbservice
            Field tech
            • 8078
            You can setup box of machine to be used as scan folder. Then map this box(scan folder) as network drive. Useful when scan to email or SMB/FTP cannot be used or easy setup.
