bizhub 420!!!
  • pierre
    • Mar 2008
    • 12
    bizhub 420!!!
    what is "F 4203" code???
    what is the problem??
    how i can solve the problem???
    plz help me!!!!
    thanks
  • masterteknicion
    • 48
    Are you sure it isn't a 2403 code. Which is a toner bottle code.
    • pierre
      • Mar 2008
      • 12
      hi again
      yes im sorry it's "F 2403"
      is there any advice to solve this problem??
      hope to hear from u sooooon.
      • redime
        Originally posted by pierre
        hi again
        You mean C 2403, not F 2403
        Take a bite out of high priced service
        Lookup the model, search the PDF there are solutions out there!
        Refers to the toner bottle being installed wrong, possibly knocking the sensor in the rear loose, or the little red "cleaner brush" has lodged into the sensor.
        • pierre
          • Mar 2008
          • 12
          thanks alottttt
          • redime
            thanks alottttt
            There are a few mods out there now to prevent the toner from being installed wrong. The new locking ring system is by-far the only "fix" I have seen -- the others have been shoe-string and bubble gum in my opinion.
            Check out the PDF for part numbers and info!
            • brent
              • Nov 2008
              • 1214
              I have had the unpleasure of putting these mods into about 5 machines so far. what I have noticed is that the new boss cover do work. but you have to replace the toner bottle sensor as well (at least I had to in my situations) and it takes quite a while to get it out of the machine. not to mention the pwb, fuser and switchback units all have to be taken off. then the finisher and everything else... so if you are not a technician and you don't have the modified parts to fix this problem I would hire a technician to do this for you. but having fixed a few I do also believe the mods do work and are still working in my machines (knock on wood)
              brent
