V CARE CONNECTION
  • blinxwap
    • Jun 2020
    • 80
    V CARE CONNECTION
    I have a bizhib 287 had to replace a EMMC and mfpb on the Mc as the network port was faulty and the EMMC had a NVRAM error code on it fitted second hand boards , Mc works fine but connecting vcare http as the mc was connected on old boards gets 3002 error code any suggestions to sort this out
    Sent from my SM-A505F using Tapatalk
  • Thayer
    • Dec 2017
    • 107
    Re: V CARE CONNECTION
    I would like to hear the happens, being I'm new to V care world.
    • byronf
      Senior Member
      • Sep 2017
      • 109
      Hi,
      You mentioned you installed a second hand EMMC, I
      Did you change the serial number as the EMMC will carry over the serial number from it original machine. Print a meter count page and confirm if the serial number matches the one on the machine, if not proceed to service mode - System 1 - Serial number and edit accordingly.
      • blinxwap
        • Jun 2020
        • 80
        Originally posted by byronf
        Hi,
        I did change the serial number
        • Bix
          • Apr 2018
          • 1421
          Hi, make sure that in Security - Enable SSL the flags for "SSLv3" and "TLS1.0" are checked.
          • emujo2
            • Mar 2017
            • 1580
            A 3002 code is "unopened CLIENT ID"..Could be machine or network related, but since you say this happened after major board replacement I would do a complete init of the device..Sounds like you may have 2 different s/n trying to go out. E
            • tsbservice
              Field tech
              • 7910
              Offtopic
              Ed, glad you're still hanging around.
              • blinxwap
                • Jun 2020
                • 80
                I have done initialization on mc , checked network subnet and gateway still doesnt connect 3002 error
                • rrrohan
                  • Sep 2011
                  • 1977
                  Try deleting on v care then intial/ram clear and reconnect at machine
                  Sent from my Pixel 4 XL using Tapatalk
                  • tech51
                    • 846
                    Firstly are they using a proxy server? That may need re inputting.
                    Also make sure the dns server ip is set correctly.
                    I have fixed many a csrc (Vcare) fault by inputting this correctly.
                    I usually initialise the network settings using dhcp auto discovery on the machine and then setting the static address afterwards.
                    Also I remember we had this fault on this model because the network speed was set to auto 1Ghz. As soon as the speed was slowed down it connected, might be worth a try as well.
                    Failing that it may be blocked if the customer is using a firewall.
                    Hope some of this helps.
                    • trscolin
                      • Aug 2012
                      • 21
                      I would for sure wipe the vcare record and recreate it in the portal. Also clear the record right off the machine and reboot it before setting up again.
                      • blinxwap
                        • Jun 2020
                        • 80
                        After months of struggle and lots of help from other techs no one could get to the mc connected on http , Finally solved this mc was registered email one way and its connecting.
                        Sent from my Hisense U40 using Tapatalk
