M2 error code in DI183
  • darkmaster
    • 50
    What is M2 error code mean for ? if M2 in CSPRO series machine is waste toner bottle full, right ?
  • dcopylady
    • 49
    M2
    If you want to know which PM is due and don't know the coding, check the life counters to see which one has reached the interval setting. (ie.....waste toner counters set at 200,000 for the life and counter is currently at 198,000)
    There is a PM life counter for the drum, the waste toner and the cleaning web. Seems like I remember the M2 being the cleaning web???
    Hope this helps!
    • mitchl
      • Apr 2007
      • 501
      I pretty sure that this machine doesn't use a web so most likely the code is for the IU life counter. It can be reset in tech rep counter mode, I believe its number 3 in the counter mode............ You may want to go ahead and change the D.V. as the machine is telling you its time!
