COF32
  • darkmaster
    • 50
    COF32
    What is COF32 in DI251 mean for?
  • Raymondd
    • Jan 2008
    • 108
    Faulty ATDC sensor.
    • minimerlin
      • 851
      Possibly lifed image unit or run out of toner.
      Please do not PM me without asking first.
      • darkmaster
        • 50
        may i try to clean up ATDC sensor then use again?
        • montana
          • Aug 2008
          • 392
          hi.check the starter if it is expired.you have to replace it.
          i wish you good luck
          • fixthecopier
            ALIEN OVERLORD
            • 4713
            If you are an end user and not a tech, you can correct your problem by replacing the "image unit" or "drum unit". You can use a refurbished one you can find easily on the net.
            • vaclav borc
              • Jan 2008
              • 75
              Chage developer and run initializing of developer.
              • albano
                • 17
                Verify the recycling gears in the IU, and then change the starter, and adjust the atdc....
                • fixthecopier
                  ALIEN OVERLORD
                  • 4713
                  If the unit has gone the full life, you would want to put a new drum in with the developer. That would be the reason to suggest the whole unit. Good info to have would be the total page count and to know when, if ever , the last change was made. Without that info a tech can not make the correct decision. I am guessing that this was started by someone who was not a tech, that is why just changing the whole unit was suggested.
                  • tango780
                    Welcome
                    You probably have been converted "Imaging Unit" from a different copier. Since the entries in the "ATDC" - "Level history" does not agree to the copier protested.. This can be corrected manually but it requires skill and time to do so-called "APLA"-page black open hatch originals)
                    For the patient, and knowledge is good (!):
                    Entered a number of higher value in your hand - "ATDC". After doing DEVELOPER exhaustion and then entered by a lower value.
                    So you must repeat the operation until the level of "ATDC" - "55."
                    NOTE! ONLY for dry mechanics!
                    This operation requires patience and accuracy.
                    If the "Developer" is a heavily used or is it enough to consume the toner at a much faster pace and the seals in the calling module will be permanent.
                    Remember, you have to enter a greater value in your service "ATDC" manually. For example, value = "69".
                    Turn off and turn on the copier. The copier will start on the manual setting of "ATDC".
                    Make about 25 copies completely black (for the open cover of the originals).
                    Go back in service settings and change the value "ATDC" on less. Lower by only a few points instance = "65".
                    The operation is repeated. You do black copies. Would reduce the value by hand. On the copier until it reaches a repeat at "Imaging Unit value similar to the" 52-55 ".
                    If you helped give to know .....
                    Yours sincerely
                    "Tango780 "
                    • minimerlin
                      • 851
                      Originally posted by tango780
                      Welcome
                      Yours sincerely
                      "Tango780 "
                      Just change the IU!!
