Ghosting black prints on bizhub c280
  • robikan africa
    • Sep 2008
    • 38
    [Misc] Ghosting black prints on bizhub c280
    Hi guys I got a bizhub c 280 not fusing black prints but everything printed on colour is fine. The black developer is ok. Drum looks fine too . The black toner rubs of easily.and their is no developer on paper
    Anyone seen this
  • tsbservice
    Field tech
    • 8019
    Re: Ghosting black prints on bizhub c280
    Black non OEM toner refill being cr.p?
    • robikan africa
      • Sep 2008
      • 38
      Thanks for reply will check and revert.
        Anyone seen this
        many points of info are missing here:
        OEM toner/dev?
        what are the page counts on PM parts?
        you mentioned GHOSTING .. that can be due to a worn out fuser
        what are the density settings?
        toner rubbing off is usually due to: bad fuser... high density settings.
        can you upload PDF'S of the defects?
        Phil B. ' The Dentist '
