C7000 Bizhub
  • afterhours
    • Mar 2017
    • 152
    C7000 Bizhub
    Good morning everyone. I have a customer with a c7000. It keeps getting the jam 9202 when doing 2 sided. I've replaced both duplex motors, all the sensors in the duplexer and the selinoid. Still keeps jammimg with the same code. I'm out of ideas. Any help.would be greatly appreciated.
    Sent from my SM-G981U using Tapatalk
    Im a Loser Baby!!!
  • qbert69
    • Mar 2013
    • 1152
    Re: C7000 Bizhub
    Any rubber feed rollers that are dusted with paper dust or glossed over that need to be cleaned with rubber cleaner???[emoji848] sometimes slippage can occur from dirty/fouled feed rollers!!! Can happen even if sensors are cleaned and motors are working!!! I've seen it happen on certain brands of machine (ahem...r!coh!) where the bridge unit between the fuser and finisher got dirty rollers and would have a slippage, delay and subsequent error code going into the finisher!!! Once the bridge unit feed rollers were cleaned, nary another jam/error code!!![emoji57]
    Sent from my SM-N950U1 using Tapatalk
    REACH FOR THE STARS!!!
    Konica Minolta Planetariums!
    • afterhours
      • Mar 2017
      • 152
      Re: C7000 Bizhub
      Thank you. I have done that.
      Im a Loser Baby!!!
      • lartis.aineias
        • 78
        Re: C7000 Bizhub
        Try to change this actuator
        Στάλθηκε από το SM-G975F μου χρησιμοποιώντας Tapatalk
        • afterhours
          • Mar 2017
          • 152
          Re: C7000 Bizhub
          Thank you. I will do that later today and get back to you.
          Im a Loser Baby!!!
          • afterhours
            • Mar 2017
            • 152
            Re: C7000 Bizhub
            You are the man!
            @lartis.aineias
            That did the trick. So weird,.it was only slightly warn at the tip of the actuator but enough to cause the problem.
            Im a Loser Baby!!!
            • lartis.aineias
              • 78
              Re: C7000 Bizhub
              You are the man!
              @lartis.aineias
              3 days I was trying to solve this problem. and when i found it i had the same reaction with you! crazy
              happy New Year!
