Problem C250 Fax forward to mail
  • stefan
    • Jan 2008
    • 8
    Hi!
    I have som problem whith a Bizhub C250 when i try to forward, fax to a mail adress. I want it to be a PDF file but it only make it as a Tiff
    the defult seting is PDF.
    Has any one had this problem??
  • buster68
    • Nov 2008
    • 181
    Faxes communicate with TIFF. Thats the only format a fax can be forwarded in. You'll need a converter program on the PC that receives the email, or just a program to open the TIFF file.
    • Taminol
      • 171
      Originally posted by stefan
      Hi!
      Stefan, the following should help you.
      1. Press the Fax key.
      2. Press Scan Settings.
      3. Press File Type and select PDF.
      4. Press the Copy button.
      5. Press Utility.
      6. Press Copier settings
      7.Press Default settings.
      8. Press Current.
      9. Enter the Tech Rep mode
      10. Press Fax tab.
      11. Press File Format.
      12. Press the start button/key.
      13. Recycle the machine OFF/ON.
      • konisolver
        System Engineer
        • Oct 2007
        • 137
        Also make sure that you have firmware phase 2 and above.
