c3350 and c3351 transfer belts interchangeable?
  • EarthKmTech
    Step aside, noob
    • May 2009
    • 2139
    I see they have different part numbers, the problem is i need a c3351 belt and only have a c3350 belt (old machine not i series)
    will it fit and work, before i try it and waste time?
  • EarthKmTech
    Step aside, noob
    • May 2009
    • 2139
    Re: c3350 and c3351 transfer belts interchangeable?
    side by side i see the difference.
    the cleaning section was completely redesigned on the c3351 including a larger diameter exit for the waste toner
    the c3350 belt does fit into the c3351 though and the shutter is opened when inserted
    i guess there is increased possibility of waste toner blockage doing this.
