Bizhub 367 , jam 20-22
  • pinspin
    • Oct 2011
    • 156
    [Jamming] Bizhub 367 , jam 20-22
    Hello! The copier jams from the second cassette, code 20-22. We changed 3 rollers and 2 clutches of the second cassette. It did not help. We would be grateful for any advice. Thanks.
  • tsbservice
    Field tech
    • 8056
    Re: Bizhub 367 , jam 20-22
    Jam 20-22 is misfeed at vertical transport section (tray 4), are you sure about second cassette?
    • pinspin
      • Oct 2011
      • 156
      oooh ,you are right friend , 20-02 my mistake .thanks
      • tsbservice
        Field tech
        • 8056
        You meant 2 oneways of pickup and feed roller shafts? If so I would try also changing torque limiter(A0ED563900) of separation roller shaft.
        • pinspin
          • Oct 2011
          • 156
          Yes ,we replaced 2 oneways and A7AH- M205 , A7AH-M204 .We will change torque limiter .Thanks .
          • tsbservice
            Field tech
            • 8056
            Let us know. Good luck.
            • pinspin
              • Oct 2011
              • 156
              Done .We replaced torque limiter and used Paper feed Guide ( with white rollers ) . Thanks for help .
              • tsbservice
                Field tech
                • 8056
                Sure not a problem. Thanks for giving always feedback not many do as you did
