BIZHUB 20
  • blinxwap
    • Jun 2020
    • 80
    BIZHUB 20
    I have an issue on a bizhub 20 constantly display jam inside single sided copies or prints page prints out than jam inside is displayed , have reset the printer fitted mew drum and toner as die old toner was dumping toner on the drum unit thought it might block a sensor or something jams from both trays after the page prints out any suggestions
    Sent from my SM-A505F using Tapatalk
    Re: BIZHUB 20
    would help to know the jam code...
    leaking toner? if you stick a screwdriver on it does some of it stick to the blade
    page counts?
    • blinxwap
      • Jun 2020
      • 80
      Re: BIZHUB 20
      page counts?
      I dont know much about the b20 so i dont know how to checl the jam codes
        Re: BIZHUB 20
        don't you have the user guide or service manual?
        • blinxwap
          • Jun 2020
          • 80
          Re: BIZHUB 20
          I will check tomorrow i will give more details then
          • allan
            RTFM!!
            • 5462
            Re: BIZHUB 20
            You can troubleshoot this machine using a Brother 8880DN service manual.
            Whatever
            • blinxwap
              • Jun 2020
              • 80
              Re: BIZHUB 20
              page counts?
              Error code 88 paper jam inside
                Re: BIZHUB 20
                Now answer my other questions.
                • blinxwap
                  • Jun 2020
                  • 80
                  Re: BIZHUB 20
                  Page count -270556 see attached pdf last toner delivery the mc is at the workshop will check if the toner sticks on the blade on or Tuesday ill keep you postedA32R042005792 - 000012275195.pdf
                  • WLIT
                    • Jan 2020
                    • 40
                    Re: BIZHUB 20
                    Remove the drum assembly and check the paper sensor flags near registration roller. Should be one before and after the roller. Your error 88 points to the flag just after the reg roller. Broken or displaced? Piece of paper in the sensor?
