biz 361 error c2801
  • Gab
    • Aug 2015
    • 676
    biz 361 error c2801
    I know this error is about TCR sensor . Can it be something else?
    Noted that at the beginning error 2558 i replaced the empty toner bottle and now i have this error.
  • copiray
    • Feb 2019
    • 29
    Re: biz 361 error c2801
    can you check the toner level in service mode?
    • Toxic
      • 698
      How many prints developer and drum have?
      Toner not OEM?
      PS:why are you so red?
      • blazebusiness
        SanDiegoCopierRepair.com
        • 1257
        First thing to try after running the bottle completely dry like that and getting a code - is to go to service mode under image process adjust and select auto toner supply and hit the start copy button. When the auto add toner is finished the copy button will turn blue again. Turn copier off and on. If you are lucky the dv unit is just starved for toner and once you run that auto toner supply it will come right back with no error code.
        If that doesn't work, time for developer or maybe a new tdc sensor.
