Touch Screens Failing
+ More Options
Posts
  • dogsbody
    • Jun 2007
    • 289
    Hi All, is anyone else having a problem with C450/C250 etc touch screens, I have had 4 fail in the week and no amount of cleaning or adjustment will help.
    Just curious to see if anyone else is seeing this in the field.
    Cheers.
    The force will be with you always.
  • fixthecopier
    ALIEN OVERLORD
    • 4713
    Nothing lately. I used to have to smack the control panel on some of the old di250/350 to get the touch screen to work.
    • 8050
      • 88
      What type of failure are you experiencing? Non-responsive touch screens? LED backlight not lighting up, contrast not working?
      • dogsbody
        • Jun 2007
        • 289
        They get out of adjustment and no amount of adjusting will bring them back.
        eg. of the four buttons to push when adjusting, the top twop will be out about 15mm while the bottom two 10mm.
        The actual screen and backlight are fine.
        Cheers.
        • kmcopier
          PSP
          • Oct 2008
          • 183
          This is the same as problem with the older models C250,C300.
          They have now two manufacters!!
          Only the good news is that it's cheap that part
          • B0265
            • Jan 2007
            • 718
            Cheers.
            We have had 5 bad touch screens on C250's in the last 2 weeks!
            • kyoceradude
              The Great Gazoo
              • Aug 2006
              • 442
              Kyocera's have had a problem with their touch screens for a while now. They had a bad batch where the conductive adhesive that attaches the flat cable to the glass, fails from heat and humidity. Possible the same manufacturer of yours. Not repairable, you must replace it.
              My mission here on Earth is to help all you Dum-Dums!
              • DCPS
                • Mar 2008
                • 116
                I can confirm the problem with the touchscreens for C250/C252/C351/C352/C450. We have had around 20 defectiv control panels the last 2 months.
                • StormyKnight
                  • Dec 2008
                  • 50
                  Strangely Ricoh have also had this problem although it has been for a while - same story humidity is affecting the glue which then throws the adjustment out & it is unrecoverable.
                  Note that Ricoh are providing the part free of charge now + a small amount for the labour to change over.
                  • emujo
                    • Jun 2009
                    • 3009
                    Hope this will help
                    • redhotrob
                      • 69
                      emujo, thanks for the info.
                      • doomblack
                        • Aug 2009
                        • 12
                        yah the touch screen on my 450 is bad, it works on occasion, I just readjust the adjustment and works for a day or two then becomes shotty again.
                        • Warstg_20
                          • Sep 2009
                          • 72
                          Originally posted by emujo
                          Hope this will help
                          thanks for this info sir
