c250i copy AND scan duplex 2 to 2 hangs
  • jmaister
    certified scrub
    • Aug 2010
    • 755
    hello folks
    got a problem where one machine always hangs at the end of sheet #2 while doing duplex 2 to 2 with copy AND scan.
    initially thought this was a data transmission issue, checked the email/tcpip setting, they all checked out. But when it exhibit the same problem with COPY jobs.
    I don't got a clue.
    fw is g00-e9, I did load it again, and no improvement.
    anyone?
    Idling colour developers are not healthy developers.
  • tsbservice
    Field tech
    • 7635
    Re: c250i copy AND scan duplex 2 to 2 hangs
    Interesting, this is on new install? Also what DF?
    • jmaister
      certified scrub
      • Aug 2010
      • 755
      Newish from last year. Has 50k on it.
      Single feed is buttery smooth
      DF714
      • tsbservice
        Field tech
        • 7635
        I would reattach everything from DF to the main body but guess you already did this.
        • jmaister
          certified scrub
          • Aug 2010
          • 755
          No, havent tried that. Machine has been in service for almost a year. Pcb Connection issue would throw codes generally? The job status also said "printwait"
          But when i iift the adf, it reports paper jam right away.
          Weird.
          Job went to a better mind. I will keep this updated as what is the solution.
          • tsbservice
            Field tech
            • 7635
            Weird.
            You can try low voltage power supply then.
            • jmaister
              certified scrub
              • Aug 2010
              • 755
              oh wow. bingo!
              that solved the problem...
              shouldnt there be a communication error if certain time has passed? iF i see an error code, i would reconnect cables. machine behavior like this throws me off big time.
              • tsbservice
                Field tech
                • 7635
                oh wow. bingo!
                I don't think machine will throw an error in most of such cases.
                Glad it worked for you.
