Duplex copying
  • patrickjlc
    • Feb 2015
    • 223
    Duplex copying
    I have a 364e that works perfectly except when doing two side copying, it will only count once. I have the machine with an external counter and when pressing duplex then start, it will show 1-2 and print. Tried it on a 454e and counts 1-2.
    This 364e will only count 1. Can make 1000 and will only count 500. On a price per copy the customer would lose half the revenue...
    Any ideas? Doing multiple copies single sided thru the ADF and glass will count normally. Only when 2 sided copying...
    Sent from my motorola one 5G UW using Tapatalk
  • tsbservice
    Field tech
    • 7973
    Re: Duplex copying
    Strange. Check and compare settings in Service mode of two machines regarding Marketing Area and Billing Settings - Counter Setting, if they differ make them equal.
    • patrickjlc
      • Feb 2015
      • 223
      Re: Duplex copying
      That fixed it, thanks
      • emujo2
        • Mar 2017
        • 1580
        Re: Duplex copying
        You need to check your billing settings in service mode..This is the only thing that would configure 2 sided only counting once..Same as 11x17 is 1 click (which I hate BTW). You can confirm this by checking the life counts, if they are increasing at the 2 clicks rate then this is the problem. E
        • emujo2
          • Mar 2017
          • 1580
          Re: Duplex copying
          Sorry, I wrote a response, went off on a tangent, came back and posted this not realizing it had already been answered. E
