Error code C2211 on Konica C6500 pro
  • mshabban
    • Jan 2017
    • 101
    Hello , I am having issues with this code c2211 on the C6500 Pro , it is intermittent coz you can run say like 20 prints then it declares the code especially when running thick paper grams, while on bond /plain paper it takes sometimes to show , I have replaced the yellow drum motor, I have changed the yellow drum , I have also changed the developer unit plus the yellow developer material, I have run out of options now , anyone with any idea please share , will truly appreciate
  • orestesp
    • Sep 2019
    • 225
    Re: Error code C2211 on Konica C6500 pro
    Hello,
    I am posting two extracts from the Active Solutions manual for the C6500. I haven't come across the code/problem you are facing myself, but hopefully these are of some help. Are you using the DU-102C drum units or the newer DU-104 meant for the C6000/C7000? Maybe a cleaning blade has flipped or some of the red screws haven't been removed prior to installing a new drum unit in the machine?
    A. C-2211, C-2212, C-2213 or C-2214 usually when the machine is running in Thick Paper mode (1/2 line speed). These are drum drive error codes.
    SOLUTION
    PROBABLE CAUSES:
    1. Incorrect drum speed. Please install minimum version 40 firmware to correct the drum speed. The latest version firmware is available via the Konica Minolta Download Selector. Access the Selector from SSD Web Support (CS Expert Support) by clicking on 'Download MSDS, Drivers, Firmware and more'. After installing the firmware please set the following DIPSW to the recommended setting: DIPSW 21 bit 6 bit 7 0 0 Default 1 0 0.1% up 0 1 0.2% up (Recommended) 1 1 0.3% up If the symptom reoccurs with the recommended value, try the 0.3% UP setting.
    2.3. Incorrect Belt Line Speed Adjustment setting. Check the setting by referring to section 10.3.8 Belt Line Speed Adj. (Printer Adjustment) in the Service Manual. If the setting value is not in the rang between -5 to -35, readjust the value within -5 to -35. If -5 to -35 cannot give the satisfactory result, also perform the section 10.3.3. FD Mag. Adjustment(Printer Adjustment).
    4. Failed Drum Drive Unit. Replace the Failed Drum Drive Unit (p/n A03U R757 00 for Yellow / Cyan ) and p/n A03U R758 00 for Black / Magenta ).
    B.C-2211, C-2212, C-2213 or C-2214 errors and the drum fails to rotate.
    CAUSE: Cleaning blade damage or Drum Drive board (PRCB) has failed.
    SOLUTION:
    • mshabban
      • Jan 2017
      • 101
      • orestesp
        • Sep 2019
        • 225
        Unfortunately, I don't have the firmware files.
        I would suggest to first check if the cleaning blade is okay.
        Sent from my Redmi Note 5 using Tapatalk
        • Toxic
          • 697
          If machine is in dirty environment it could be dirty encoder sensors on drum drive at the back of machine.
          Little tricky to get them out to clean.
