disable the motion detector
  • mantg
    • Sep 2015
    • 3
    Does anyone know how to disable the motion detector(proximity sensor) on the Konica Minolta bizhub C3350i?
  • tsbservice
    Field tech
    • 8020
    Re: disable the motion detector
    [Utility]
    [Administrator]
    [Maintenance]
    [Timer Setting]
    [Power Settings]
    [Awake from Power Save Mode by Touching Control Panel]
    Turn it Off
    • mantg
      • Sep 2015
      • 3
      [Utility]
      [Administrator]
      [Maintenance]
      [Timer Setting]
      [Power Settings]
      Turn it Off
      I had just found and yes it is this setting Thank you.
