Konica Minolta C350 scanning defaults
  • timcouch
    Hello,
    I have a bizhub c350 that I just started using for scanning. I am using the ftp client to scan directly to the users station. The issue i'm running into is, when you scan it defaults to color which is making the pdf file size large. Is there a way to set the default to black and possible 300 dpi instead of 200?
    Thank you,
    Tim
  • 8050
    • 88
    Yes, to set scan defaults follow these steps:
    1. Hit SCAN button
    2. In SCAN MODE select BLACK
    3. In RESOLUTION select 300
    4. Hit UTILITY button on left
    5. Select STORE
    6. Select RESET MODE
    7. Select CURRENT MODE and hit SET
    8. Hit ENTER 2x's
    9. Exit
    Your scan defaults should be as you set it.
    Hope this helps!
    • timcouch
      thank you
      Thank you very much for your post.
      Tim
