Bizhub C558 - Deleted Certificate
  • copy2112
    • Mar 2021
    • 2
    I'm afraid I may have done something stupid. I was troubleshooting why scan-to-email wasn't working with O365. We have a SMTP relay setup in O365 so scan-to-email was setup to send to port 25. Ina forum post, someone said that they had resolved the same issue by deleting the certificate under Security > PKI Settings > Device Certificate Setting on the browser interface. I first exported the certificate so I could import it back in if there was an issue. I then removed the certificate. I was then kicked out of the administrator login. I tried logging back in and just get "Cannot perform service.[Sub Power OFF]".
    I am remote so I am hoping that if I have someone power cycle the copier, I will be able to get back in. Is that the case or have I locked myself out for good?
  • rrrohan
    • Sep 2011
    • 1977
    Re: Bizhub C558 - Deleted Certificate
    If it's got no certificate anymore you'll have to use http not https
    Sent from my Pixel 4 XL using Tapatalk
    • copy2112
      • Mar 2021
      • 2
      If it was setup as https, will it default back to http or do I have to go into the local console and disable SSL in order to get in through http? Once I get back in, I can import the cert that I had exported.
      • emujo2
        • Mar 2017
        • 1579
        If it wants a power cycle then you must finish the request. Once it comes back up I recommend using a different browser to go in and rebuild your certs as the old HTTPs will be cached. E
