Bizhub 454e - Serial number must be entered (contact service representative) display
  • Perrard
    • Mar 2021
    • 1
    [Error Code] Bizhub 454e - Serial number must be entered (contact service representative) display
    Serial number must be entered (contact service representative) displays at start up.
    This occurred when the drum was at 1%, so I replaced it and still have the same error.
    How do I get rid of the message?
    In the utility section, it now shows the drum at 100% since I changed it.
    Appreciate any feedback!!!!!
    • 37488
    Re: Bizhub 454e - Serial number must be entered (contact service representative) disp
    Sounds like you are an end user. As the display suggests you need to call a trained and qualified service representative. There is a tech simulation that needs to be ran to clear the message.
    • tsbservice
      Field tech
      • 8013
      Not a drum problem. Maybe bad backup battery. Still will need KM tech to proper troubleshoot it.
