KONICA MINOLTA C250i C300i C360i ...
  • copiers01
    • Mar 2018
    • 23
    [Electrical] KONICA MINOLTA C250i C300i C360i ...
    This is another damaged Toshiba KBG3AZMS256G drive in the C250i
    Can anyone recommend something more stable for the c250i.
  • tsbservice
    Field tech
    • 8013
    Re: KONICA MINOLTA C250i C300i C360i ...
    Do you mean you've replaced original storage board with this Toshiba SSD? How many you replaced and why - machine didn't boot?
    Can you be a bit more specific, Thank You.
    • copiers01
      • Mar 2018
      • 23
      Some time ago I bought several C250i / C300i devices. Most of them had the STRGB Toshiba KBG3AZMS256G on board. The problem was repeated on three devices, namely the device hangs on the Konica Minolta sign. The machine does not accept the software. I wanted to exclude the CPU and the motherboard so I used STRGB from another working machine. Using an adapter, I connected the STRGB to the computer and then made the format. Then I put the STRGB in C250i and did the initialization. After uploading the software, the machine is operational.
      Can anyone recommend some stable M2
      • Walterj
        KONICA MINOLTA
        • Jun 2017
        • 89
        • Bix
          • Apr 2018
          • 1421
          You can fix this problem with FW G00-B6/G00-E9.
