C454e Toner low Sign
  • ck1
    • 485
    I have few C454e after replace toner still getting toner low sign didn't reset any issue please advise thanks
    • 22808
    Re: C454e Toner low Sign
    OEM genuine toner?
    customer replaced?
    • rrrohan
      • Sep 2011
      • 1971
      I'd remove toner, run multiple full bleed test pages in that colour until it asks for toner to be replaced then reinstall toner cartridge
      Sent from my Pixel 4 XL using Tapatalk
      • ck1
        • 485
        OEM genuine toner?
        customer replaced?
        Yes. but some is rechip
          • 14752
          What do you mean by re-chip?
          • ck1
            • 485
            refill toner and new toner chip
              • 14752
              I'd say it's a high likelihood that the chip is the problem.
              It's a good thing that Phil asked. Saved a lot of time.
                • 22808
                so it's NOT OEM genuine
                that could be your problem bucko
                are you even a trained tech?
                About ck1
                Country:Malaysia
                Contact
                This Page https://www.copytechnet.com/forums/members/ck1.html
                Statistics
                Can't tell by your profile
                I'm done
                • Gift
                  • Mar 2011
                  • 2413
                  I noticed that the C454e ignores a new toner if a customer replaced it before actual toner end condition.
                  Solution:
                  1. ignore the false toner remaining prognosis
                  2. remove the toner and run full bleed color patterns until the MFP says "toner end" then re-insert the toner
                  • patrickjlc
                    • Feb 2015
                    • 212
                    Run oem toner and wont have any problems. Those aftermarket chips are hit or miss....
                    Sent from my motorola one 5G UW using Tapatalk
                    • tsbservice
                      Field tech
                      • 7635
                      I'm sure this is right strategy for C224e-364e which toners don't have chip. But don't have this model in field. Will it work if toner has a chip? Or machine will ask to put toner inside and refuse to work?
                      • Gift
                        • Mar 2011
                        • 2413
                        In my "EU" market region I can run a C454e/C458 even without a toner installed so it seems the MFP does not really care about the chip. This fix works for me, too.
                        • tsbservice
                          Field tech
                          • 7635
                          OK, got it. However I'm pretty sure on C250i series will not run without one of toner cartridges.
