KM C454e Light spots on blue prints
  • andrecopfac
    • Feb 2020
    • 17
    [Misc] KM C454e Light spots on blue prints
    I have ventured on Konica minolta C280, 454 for at least 7 years, I caught a problem recently.
    Some stains in blue color, the blue developer of the developer is uncovered from the developer, even if full, it replaces the developer unit and in the same place it becomes clear, without developer cover.
    I notice a significant improvement by changing values ​​in "transfer output fine" to a negative value.
    Any suggestion ?
    I discarded the imaging unit because I already made an exchange
    I changed the revamping unit already. And nothing solves.
    Re: KM C454e Light spots on blue prints
    Any suggestion ?
    are they using crap rd party toner?
    whats the life on service parts?
    is machine clean?
    what is a 'revamping unit'?
    • andrecopfac
      • Feb 2020
      • 17
        Are those supplies meant for your box?
        Not all dev and toners are compatible between models.
        If you are refilling with non compatible even within the brand that could be the problem.
          Sounds mighty risky to me. Just saying.....
          • tech51
            • 846
            • tulintron
              • Jul 2014
              • 669
              • allan
                RTFM!!
                • 5459
                Clean your mag roller. Got some kind of contaminant on it like oil.
                Whatever
                • tulintron
                  • Jul 2014
                  • 669
                  On your C280 I advise supplies for the C8000 because we have already tested it in our laboratory and I can say.
                  On your C454 I wouldn't do it again
                  TSB knows a little about the crazy things we do in the laboratory. Hahaha.
                  • allan
                    RTFM!!
                    • 5459
                    Wanted to try that. Can get a bunch of DV613K that is stuck in a suppliers stock, that means cost price or less.
                    What was the ill effect you had on the C454?
                    End of side track...
                    Whatever
                    • andrecopfac
                      • Feb 2020
                      • 17
                      • andrecopfac
                        • Feb 2020
                        • 17
                        Here everything is generic (Image cylinder, charger grid, transfer belt).
                        I always had a problem with flat and lighter colors.
                        Yesterday I cleaned the transfer belt rollers, and apparently the problem improved a lot. I noticed that it was very dirty and with 2 a4 sheets on top, before the cleaning blade.
                        Was that the problem?
                        • andrecopfac
                          • Feb 2020
                          • 17
                          • andrecopfac
                            • Feb 2020
                            • 17
                            • tulintron
                              • Jul 2014
                              • 669
