Prints are peeling on the edges on Bizhub C364 & C454
  • Hishamawada
    • 174
    Hello,
    When printing on stickers (thick 2) and 300 gsm (thick 4).
    Tried slowing the speed of the fixer and still same , tried increasing the temp also same .
    Any ideas what i could do?
    Sent from my SM-G610F using Tapatalk
  • Max
    • Oct 2011
    • 555
    Re: Prints are peeling on the edges on Bizhub C364 & C454
    Make sure it's not inkjet/photo paper. Or the pressure is no longer sufficient due to worn out fuser. Compatible toner?? If so, melting point probably different.
    • Hishamawada
      • 174
      300 gsm media is normal glossy paper and the stickers are for digital printers . yes compatible toner is used in both machines . Should i just increase the fixing temp for this specified thickness ?WhatsApp Image 2021-02-22 at 11.07.25 AM.jpg
        Originally posted by Hishamawada
        300 gsm media is normal glossy paper and the stickers are for digital printers . yes compatible toner is used in both machines . Should i just increase the fixing temp for this specified thickness ?[ATTACH=CONFIG]48893[/ATTACH]
        Ditch the crap toner.
          • 37382
          Not only different but inconsistent. A variation as little as 1 degree C in the melting point can be the difference between fusing properly sticking to the fusing roller/belt/sleeve. Use only Genuine KM supplies and parts. Otherwise as the old Fram oil filter says,
