issue with FS-534
  • Boyaka1989
    • Mar 2021
    • 16
    issue with FS-534
    hi how can solve an issue with my finsher that keeps stapling (5 times) after every wake up or if i open the door it did not use to do that before just started to happen ,i took it apart cleaned and put it back still happening i updated the firmeware still noting ,
    any suggestions?
    • 14489
    Re: issue with FS-534
    any suggestions?
    Is it actually producing staples, or just dry firing?
    If it is not producing staples it means it is trying to advance the next layer of staples. That indicates an issue either with the current staple cartridge or the stapler itself. Try another new cartridge. If that doesn't work it is probably best to have an authorised tech look at it if you are not one.
    • Boyaka1989
      • Mar 2021
      • 16
      it is producing staples
      • tsbservice
        Field tech
        • 7968
        Perhaps stupid question but did you try to power off and unplug the machine for a minute?
          • 14489
          Try what tsbservice suggested.
          If it is producing staples it doesn't see the next layer advancing. Sounds like a staple unit problem. It may be as simple as a stray staple stopping the unit from recognising the staples.
          Remove the current cartridge and check the staple unit for stray staples. Install a new staple cartridge and try that.
          Replacing the staple unit may end up being the answer.
          • Boyaka1989
            • Mar 2021
            • 16
            okay when i encountered this issue i did the following; unpluged and waited ,updated the firmware ,replaced the staple cartridge and took out the finsher and cleaned the sensors checked if any stapels stuck nothing helped . the machine is working and stapling my documents but everytime the wakesup its just stapling 5 to 6 times using up the staples .
            • allan
              RTFM!!
              • 5462
              Then must be on the stapler unit itself as mentioned . When a new cartridge is installed it will staple 5 times. Not sure if it will do it even if you manual advance the staples then installing it.
              Take the unit out and check to see if it advances the staple correctly and it the sensors are in check.
              Whatever
              • DK-tech
                • Apr 2021
                • 25
                any suggestions?
                I have seen this now and again. first change out the whole stabler magazine/container. If still a problem, then change the stapler unit.
                • Techlife
                  • Mar 2015
                  • 27
                  For what its worth, ive had about 5 or 6 of these, and its always been stuck staples in the cartridge
