Bizhub c360 black quality issue
  • tsbservice
    Field tech
    • 7983
    Re: Bizhub c360 black quality issue
    Originally posted by wynter17
    No,i replaced with new parts,in my country these parts are cheaper,all oem,the tcr value is at 6%
    Sent from my SM-G980F using Tapatalk
    Good for you maybe we should use Romanian distributor instead of ours
    In that case check what Toxic is pointing I have similar problem with failed black developing solenoid on C224E model.
    • wynter17
      • Mar 2019
      • 33
      Okay,thanks for your help! Yes but the printers are more expensive
      • mga
        Copier Technician
        • Dec 2010
        • 1393
        Hello,i have the followinh problem with a bizhub c360,everything was replaced, image unit,transfer belt,toner,developer unit,and the problem still persist.
        Does someone know what could be the problem?
        Thanks in advance
        It's the black development assembly common problem
        Regards Mark
          but he looked at it and it looks good .. not sure if he took it out and turned the mag roller or not.... didn't post pics of the mag roller either so we 'have to take his word for it'
