Konica MINOLTA BIZHUB c258 FTP serwer access
  • Xorcode
    • Apr 2021
    • 3
    Hello everybody!
    My question is about embedded FTP server on Konica MINOLTA BIZHUB c258
    On device I turn on FTP server type a ip address of my device, and device ask me about credentials. I've tried several times to log in as Admin or Administrator using default password that i found (12345678 or 1234567812345678) but I failed. Where can i find information about this or how can i set credentials ? To be sure i use wireshark to see what is going on.So Konica minolta ftp server is sending acknowledgement that server i ready and browser try automatically to log in as anonymous User and password is balnk I think buy i am not sure.
  • and
    • Oct 2011
    • 99
    Re: Konica MINOLTA BIZHUB c258 FTP serwer access
    I only know this for data capture
    login : capture
    password : sysadm
    old model
    To allow FTP print with the arbitrary user name (include null) and login without password request.
    DipSW No.228 (bit3)
    0x00: Disable (Default)
    0x08: Enable
    Note:
    -It is necessary to switch the function of FTP port in order to print via FTP protocol on MFP.(DipSWNo.72(0bit))
    • Xorcode
      • Apr 2021
      • 3
      thank you for the information i will check it out and let you know it is working
      • Xorcode
        • Apr 2021
        • 3
        So....
        Login and Password jackpot but
        another error occurred
        452
        Requested action not taken. Insufficient storage space in system. File unavailable (e.g., file busy)."
        I check storage space i got plenty
        So thank you for login and Password it works
        • rrrohan
          • Sep 2011
          • 1977
          are you trying to upload or download when that msg appears
          • and
            • Oct 2011
            • 99
            I try on 454e and work.
            Switching between device counter and printing function on FTP port
            Software Switch No.72 (bit 0)
            0x00: Enable to obtain device counter using FTP / Disable printing function using FTP (default)
            0x01: Disable to obtain device counter using FTP / Enable printing function using FTP
            *When DipSW is Enabled, input the following user ID and password.
            User: ftpprn
            Password: FTP6626
            C:\Users\Admin\Desktop>ftp 192.168.100.18
            Connesso a 192.168.100.18.
            220 KONICA MINOLTA FTP server ready.
            502 Command not implemented.
            Utente (192.168.100.18(none)): ftpprn
            331 Password required for ftpprn.
            Password:
            230 User ftpprn logged in.
            ftp> put test.pdf
            200 PORT command successful.
            150 Opening ASCII mode data connection for ftpprn.
            226 Transfer complete.
            ftp: 497226 bytes sent in 0.30secondi 1646.44Kbyte/sec)
            • rrrohan
              • Sep 2011
              • 1977
              User: ftpprn
              Password: FTP6626
              Password:
              ftp> put test.pdf
              isnt switch 72 for usb memory back/import
              • B0265
                • Jan 2007
                • 718
                SW 72 bit 2 is for USB memory export/import.
                • rrrohan
                  • Sep 2011
                  • 1977
                  Bit 4
                  Sent from my Pixel 4 XL using Tapatalk
                  • and
                    • Oct 2011
                    • 99
                    bit 0 is for "To enable/disable printing function on FTP" (HEX 01 to enable)
                    bit 2 is for "Import/export function of the address book through the USB memory" (HEX 04 to enable)
                    bit 3 is for "To specify default tray for FTP printing" (HEX 08 to enable)
                    If you want enable all HEX 0D
                    • rrrohan
                      • Sep 2011
                      • 1977
                      I must be get bit and hex mixed up
