B36 tool to edit serial number
+ More Options
Posts
  • blinxwap
    • Jun 2020
    • 80
    Hi guys i recently had to change the MFPB on a b36 ssd was faulty now i heard theres a tool to change the serial number as it cannot be change in service mode i have tried it cant be done, can anyone assist me with the tool or how i can access the techdoc or dtechdoc site i heard it can be downloaded from theres
    Much appreciated
    Sent from my SM-A505F using Tapatalk
  • strider5555
    • Jun 2008
    • 96
    Re: B36 tool to edit serial number
    Here are the files and instructionsbizhub36_42_Serialnumber%2Bwriting%2Bfiles.zip
    • blinxwap
      • Jun 2020
      • 80
      Originally posted by strider5555
      Here are the files and instructions[ATTACH]49061[/ATTACH]
      Thanx much appreciated
      • blinxwap
        • Jun 2020
        • 80
        [QUOTE=blinxwap;1754891]can this tool be used to change the meter reading also or is there another tool which i can use to change the reading
        • tsbservice
          Field tech
          • 8032
          [QUOTE=blinxwap;1810617]
          Why?
          • Synaux
            • Mar 2012
            • 1224
            How did I know that this would be the next question...
            • emujo2
              • Mar 2017
              • 1579
              [QUOTE=tsbservice;1810620]
              Why?
              Well, when you work for John Gotti copiers, that's just the way you do things. E
              • tsbservice
                Field tech
                • 8032
                I don't know if he is working for a copier dealer or Mafia. But you're right fellow tech is different than others.
                • blinxwap
                  • Jun 2020
                  • 80
                  We cant correct the reading to log off the tsa's cause on our system it still shows the old reading after board replacements we could adjust the reading on the newer machines but not on the older machines thata the reason why im asking so the client are billed at minimum billing not the actual copies they making
