Konica 2125 - clean drum
  • Konica 2125
    If someone can please help me here. I have an old konica 2125 that the drum needs cleaning on (lots of black lines on paper). the local repairer has said it is wasting their time and my money and they don't wish to service it. Can someone give me instruction on how to get the drum out so I can clean it.
    thanks for your help.
  • Zoren
    Technicien de copieur
    • 99
    same thread.............
    http://www.copytechnet.com/forums/ko...lean-drum.html
    Just came out from hybernation.....
    • doma873
      • 24
      Its need a new cleaning blade. They were the same as 2028 3035 4045 series and 3135 etc.
      There quite easy to change. Must use setting powder
      • kiwitechnician
        • Dec 2008
        • 54
        I can't believe this machines are still alive
        • Konica 2125
          Yes this one is just working and I need to know how to get the drum and blade out so I can clean it. I know roughly the location but not sure on the rest. If i reck it completely no more loss then i have at moment so i wish to have a go if you can help.
          thanks.
          • Zoren
            • 99
            this konica model is easy to maintain....
            if can you manage to remove the drum w/o scratching it, just follow my first reply to your thread it will be ok... u can also use toner or even baby powder to coat all over the drum so that the cl. blade wont flip over when you turn the machine on coz thats your worst nightmare when that blade flips over and you will know something went bad....
