Konica Minolta C3320i- Storage Format
  • Franco107
    • Nov 2020
    • 16
    Hi guys,
    I have a C3320i in the showroom and would like to do Storage Format and Storage Lock.
    I've tried but the did not succeed. The Encryption Settings has not been encrypted.
    Appreciate all your response in advance.
    Thank you.
  • Max
    • Oct 2011
    • 557
    Re: Konica Minolta C3320i- Storage Format
    I belive there's a storage option under utility. Formating option is there. Not sure about encryption.
    • Gift
      • Mar 2011
      • 2459
      Does the "budget focused" C3320i even come with a proper m2 hard drive? Spec sheet says "16gb HDD" that might be just a memory card connected on the onboard micro-SD slot - so it wouldn't surprise me if HDD encryption/format is not possible via admin menu. Try a data clear via service mode then.
      • emujo2
        • Mar 2017
        • 1579
        F/W G00-45 supports this..BTW km has removed all f/w versions before 45..I can only think that they found massive issues and do not want these used anymore..I found out by trying to reload ver 24..
        • tsbservice
          Field tech
          • 8009
          Originally posted by Franco107
          Hi guys,
          Thank you.
          Those are MicroSD Storage equiped models.
          1. Storage Format can be found under:
          • [Utility]
            • [Storage Management]
              • [Format]
          2. Since microSD does not support the selfencryption function, Storage Lock Password setting is not available.
          • Franco107
            • Nov 2020
            • 16
            Yes, the format and encryption system settings option are there but I would also like to do Storage Lock which is not available in this model.
            Thanks for your help.
            • Franco107
              • Nov 2020
              • 16
              Thanks , would try a data clear via service mode.
              • Franco107
                • Nov 2020
                • 16
                I'll update the F/W G00-28 to G00-45.
                Thanks,
                • Franco107
                  • Nov 2020
                  • 16
                  • [Utility]
                      • [Format]
                  Have noticed that too. Is there anything else I can do?
                  Thanks,
