Hey guys... I have a problem with a Bizhub CF3102 throwing a COBAO code and I know that it's the finisher cause it made a wierd noise when it did it...
Now, I can't get the code off of the screen with the finisher connected or disconnected on the machine. The machine is down and will not clear.. I don't understand why even with the finisher disconnected...
Is there a sequence to erasing codes on a Minolta. How do I clear this code so I can use the machine again?
Thanks for your help
